820-02100 5V 0A
ajdoc
Board with liquid damage.
PPBUS_AON = 12.29V
PP3V8_AON = 3.78V
PP5V_S2 = 0V (pulsing)
PP1V8_S2SW = 0V (pulsing)
PP1V8_S2 = 0V (pulsing)
PP1V2_AWAKE = 0V (pulsing)
PP1V2_S2 = 0V (pulsing)
PP0V95_S2SW_VDD2L = 0V (pulsing)
PP0V855_S2SW_VDDCIO = 0V
PPVDD_ECPU_AWAKE = 0V
PPVDD_DISP_AWAKESW = 0V
PPVDD_AVEMSR_AWAKESW = 0V
P2V5_NAND0_SW = 0V
PPDCIN_AON_CHGR_R = 5.14v
PPVIN_P1V8VDDH_DRMOS = 12.31V
P1V8VDDH_SW2 = 0V
PMU_VDDHI = 2.55V
ajdoc
Yes, board alone
Affect areas:
UP800 (removed at the moment because there was short on PP5V_S2_MAIN
UD770, C7702, QP700, U5700, UD500, C5150, UR200, R8170, R1983, CE412, UE022
Many of the mentioned components connect with CPU; it may be damaged already.
PMU_VDDHI is correct, so U8100 should deliver steady LDOs.
Check them for voltage pulse and diode mode to ground.
Also check U7700 LDOs.
I suspect you have more corroded components, or traces; even under some BGA chips.
