820-02100 low p3v8_aon
Outofwhack
Lady's a2485 just stopped.
No visible liquid damage to board
5volts 20mA not connected to battery, trackpad
ppbus_aon 12.3v
pp3v8_aon oscillating 2.5v to 3.4 avg 3.2v (low)
I noticed U5700 has an erratic input voltage pp5v_s2_main 0.6v to 5v
p5vs2tps_pwr_en 0.2v but Im going around in circles thinking this could be caused by low pp3v8_aon
Ive replaced U5700, no change.
Im lost
Check diode mode to ground on all secondary power rails.
Pay atention to SSD power.
Compare readings with good board, or reference table.
Outofwhack
I do happen to have another non-working board - measurements from this in brackets at end of line
pp5v_s2. 0.3v close to OBdata 0.39v
pp1v2_s2 0.2v close to OBdata 0.26v
pp1v8_s2 0.22v close to OBdata 0.255v
pp1v8_aon 0.4v close to OBdata 0.44
pp3v3_s2 0.37v close to OBdata 0.4v
pp2v5_nand0 0.265v similar to OBdata 0.302v
p1v2_lx0_nand0 0.295v close to OBdata 0.305v (0.256)
p0v9_lx0_nand0 0.124v significant less than OBdata 0.345v (0.167v)
p0v9_lx1_nand0 0.124v significant less than OBdata 0.345v (0.167v)
ppvin_p3v8nand0 0.3v significantly more than OBdata 0.161v (0.189)
Are any of the last 4 rows enough to suggest anything?
Sudden death is many times caused by failed NANDs; even no short detected.
If CPU can't access its dedicated partition on SSD, it can fully boot.
Outofwhack
I tried that. After turning off pp2v5_nand0 the other [20v capable] non-working board still got to 20v.
So I suspect this would indicate that reading a NAND partition is not required before going to 20v.
Can any other area explain pp3v8_aon oscillating 2.5v to 3.4 avg 3.2v?
I had one A2141 switching to 20V with shorted SSD (2V5_NAND), but I was not sure about M1 machines.
Possibly problem with a secondary power supply.
You should check all of them in diode mode; including master/slave rails.
Outofwhack
As a long shot I tried my thermal camera and with only 20mA draw the hottest chip was an audio amp at 30c supplied by 3v8_aon. I lifted it and found corrosion under the chip! Problem solved. Thx for your help.
Outofwhack
I delayed sending this one back to the customer too quickly as I wanted to leave it on the shelf for a few days and make sure it will take a charge. Again it has drained the battery to 0% and won't start charging. Cmizapper battery tool reports TCA and DSG. I tried a new battery too - same result. Approximately how much should the idle drain current be when fully asleep?
