820-02536 (A2681) - Stuck at 5V
I have a MacBook Air M2 (13” / 820-02536 / A2681) that is stuck at 5V.
It had water damage in the following areas:
  • F5200 was blown and has been replaced.
  • R8450 (pin 1 / PPBUS_AON): the pad was missing. After restoring the pad, PPBUS_AON could not be measured there for some reason, so I ran a wire from F5200 (pin 2 / PPBUS_AON) to R8450 (pin 1). PPBUS_AON can now be measured there and at RD531/XWD530 (pin 1).
  • PPVBAT_AON_CONN was shorted to ground; the short has been removed and now measures 1.106 in diode mode.
Notes:
  • PPBUS_AON is not stable. When F5200 is removed, PPVBAT_AON_CHGR_REG is stable.
  • U5200 has already been replaced, with the same behavior.
What should I check next?
R8450 = 887kOhm
R8451 = 453kOhm
PBUS_DIV = 3.6-4V (not stable)
PBUS_DIV_SNS = 3.5-3.7V (not stable)
PP3V8_AON = 3.5-3.7V (not stable)
Possibly more liquid damage on secondary power rails, or other sensors.
What about M/SPMU LDOs?
Compare diode mode readings with good board.
Did you test with charged battery?
With battery connected I just get an apple logo (without progress bar).
It jumps up to 20V.
Already tried to get it into DFU, doesnt work. (even with FORCE method)
I only get 20V when I press hard on the battery connector.
I will replace it and try again.
Note: Multiple layer damage on that spot, had to remove multiple layers to get rid of the dead short on PPVBAT_AON_CONN
