820-02536 board Air 2022 A2681 with power cycling on USB
sekidata
This 820-02536 presented with areas of liquid damage in the R_SPKRAMP area near UN000. I removed two corroded caps that had shorted PPBUS_AON and PP1V25_AWAKE_NAND to ground.
Now, connecting a charger gets PPBUS of 12.3V and 5.1 on USB-C. The charger gets to 20V but as soon as it does, the connection is reset to 5.1V and power cycles as such. Same behavior on all 3 ports.
I checked all large coils as well as the smaller MPMU and SPMU output coils and could not find shorts to ground. No component is getting hot during cycling. There’s obviously a short somewhere, how do I find it?
PPBUS and 3V8 are steady for a few seconds, until the power resets and all rails dip to zero. Need to check the LDOs.
I did and nothing changed at all. The battery could be empty though. I need to verify on another A2681 machine.
Check diode mode on any switch, like in pages 48, 76, 78.
A good battery tester is a "must have" tool nowadays.
This is the cheapest and best option, especially designed for Apple repair.
Harald has also a battery simulator for some MacBook boards.
I just found out that PPVBAT_AON_CONN is 15Ω to ground. When I inject 3V into PPVBAT_AON_CONN, the only thing getting warm is the CPU. Does that make any sense?
The battery connector was internally shorted. Removal of the connector removed the short. Now onto getting a new connector and back to testing with a good battery.
All pins on UD200 measure good - identical to a known good board.
On battery power alone, the AON rails (PPBUS, PP3V8, PP1V8, PP3V3) are steady but all other power rails cycle (turn off every second).
If I can't find any shorts on any secondary power rails, why are the PMUs cycling on and off? How do I find out why the charger resets?
It’s still the same cycling as I wrote earlier. Both are steady for a few seconds (12.3 and 3.8) until the charger resets and all rails dip to zero.
