820-02655-05 Waterdamage
Tizang
i have an 820-02655-05 with an water damage but no obvious damage. If i attach it to the power supply, it draws 5V and 0,001A jumps after 1sec to 5V 0.13A and then immediately restarts.
I already checked PPBUS_AON, 3V8_AON an the CD3217. Alle function normal.
Can you help me solve the problem? Thanks in advance!
Which area has been affected by liquid?
Remove F5200/1 and see if power meter still restarts.
Almost everything. What is the F5200/1? I cant find it in the schematic. After removing this fuse, the macbook is still restarting. The fuses on the top also look burned but the values are normal with 0.48V in Diode Mode. Is there are program for macbooks like zxw for phones where it is possible to see the right diode mode value. Thanks in advance. IMG_3595 Large.jpegIMG_3596 Large.jpegIMG_3594 Large.jpeg
I replaced them with new ones and its restarting again. Should i remove them again and then insert power on the line and look where heat appears?
I meant to check voltage on both sides of mentioned "W" fuses; both removed, of course.
I expect to get 12.3V one side (not on PPBUS_AON).
OK, so the input circuitry is good.
What is diode mode to ground on the side without voltage?
Chreck it on all big coils also.
Don't forget LN4/980...
In Diode Mode to ground its 0.5 on the side without voltage.
LH900 = 0.43V
LG800/801 =0.45V
LN980, LN930, LN920, LN921 = OL
L5230 = 0V
L9500, L9620, L9400, L9420, L9600 = 0.095 V
LT000 = 0.4V
L5840, L5800, L5820 = 0.38V
LC260 = 0.4V
LN480 = 0.31V
LN420/21 =0,36V
LN430 = 0.279 V
LF800 = 0.31V
LP800 = 0.4V
Alright.
L5230 = 0.5
LN480 = 0.32
LN980 is OL because it isnt soldered in
The other values are all normal expect L9500, L9620, L9400, L9420, L9600 = 0.095 i would say.
Alright. But it will restart then again. Liquid is on top and bottom of the area near the display cable.
"check diode mode to ground on all small coils around both PMUs (U8100 & U7700)"
No need to apply power for that!
Use similar board as guide to make an idea about diode mode readings on the areas affected by liquid.
Thank you. How can i access the openboard data? When i click on the 820-02655 it just says as follows. I dont know how to access the data. I use FlexBV 5.xx for the schematics.
HEADER_DATA_START
OBDATA_V002 https://openboarddata.org
TIMESTAMP 1768387030
BOARDPATH laptops/apple/820-02655
ID 820-02655
BRAND apple
CATEGORY laptops
COMMENT Macbook Pro 14" M2 A2779
HEADER_DATA_END
### Released under the OBbL - https://opendatacommons.org/licenses/odbl/1-0/
DIAGNOSIS_DATA_START
DIAGNOSIS_DATA_END
COMPONENTS_DATA_START
### Component Category Value Comment
### v = value, p = package, c = manufacturer code, r = rating, m = misc, s = status
COMPONENTS_DATA_END
NETS_DATA_START
### Network Valuetype Value Comment
### d = diode, v = voltage, r = resistance, a = alias, t = net comment
NETS_DATA_END
### END
No data there for your board.
I gave you the main link; try to find a similar board in the list, with available readings.
