820-02773 MacBook Air M2 dont turn on
Dozer
Hi have now the same problem like in
Fanspin, no display no trackpad clicking, no extern display, no caps lock led reaction. switches from 5 to 20 and later to 19.xxV like usually so power consumtion looks normal
DFU mode is possible but had no effect
found PP5V_S2SW_USBC01 has 0V
but UPC01_5V_EN has 0 V
PMU_SYS_ALIVE_1V8 is 1.8V
PP1V8_S2 is 1.8V
"wich signals needs to turn on UPC01_5V_EN ?"
It is driven high when external device is connected to corresponding port; it enables 5V output required by external devices.
the ampmeter goes from 5V to 20V then a bit later to 19.xx V
the second device on my table and ia am stuck in the same problem.
Neet realy help to diagniostic that problem
5V_S2SW only appears (on corresponding port) when external device is detected.
Your MLB behavior denotes that it doesn't detect any device.
Such 5V is not required in DFU, as the other Mac has its power supply.
Can you find all voltages from pages 108-111?
