820-03286 (A2941) - No PPBUS_AON / Stuck at 5V
I have an 820-03286 (A2941 / MacBook Air M2 15” 2023) that has no PPBUS_AON and gets stuck at 5V / 0.05A.
Note: I replaced U5200 because PPCHGR_VDDA/VDDP was only at 4.5V. After replacing it with an ISL9240 (from a MacBook Pro M1 2020), it’s now back to 5V.
Current measurements:
  • CHGR_AUX_DET: 0.8V
  • P3V8AON_PWR_EN: missing (Diode: 0.485)
  • P3V8_AON: missing (Diode: 0.317)
  • PP5V_AON: missing (Diode: 0.494)
  • P5VS2_PWR_EN: missing (Diode: 0.485)
  • PP5V_S2: missing (Diode: 0.485)
  • PPBUS_AON: missing (Diode: 0.485)
Any suggestions on where to start troubleshooting from here?
PPBUS_AON MUST appear first.
It supplies all secondary power supplies, including 3V8_AON.
Any history available?
Did you check diode mode to ground at PPBUS_AON?
Yeah I have added the diode value, please check again.
UT360 (Line: PP3V3_S2_HOLD_IPD) was shorted, I have replaced it - short was gone.
But now it stucks at 5V (Before it was booting fine but without keyboard/trackpad functionality)
PPDCIN_AON_GHGR_R = 5V
R5221/5222/5261/5262 = 1ohm (Note: R5261 was at 100kohms, I have replaced it with 1ohm - still no PPBUS_AON)
Is the ISL9240 not compatible with the A2941? Before replacing it with ISL a RAA489900A6 was in use.
I’ve already ordered two (just in case). I’ll let you know if it fixes the issue or not.
Note: I’ve tried it with a known good ISL9240 - seems like it is not compatible (at least on the A2941).
Other “issue” … the right speaker is sometimes crackling at 100% volume with heavy bass, I have already tried a new speaker same behavior - any idea?
Edit: The trackpad haptic feedback is also unreliable (50/50 not working/working) I have already replaced the cable, same behavior - seems like a board issue, where to start?
PPBUS_AONSW_TPAD = 0V
Trackpad and keyboard are working. (just feedback doesnt work)
Edit2: Now it doesnt power on - Stuck again at 5V / 0.03A (PPBUS_AON = 12.27V)
I have noticed that P5VS2_EN and P5VS2_PWR_EN are not stable (0.6-1.3V / 0.650)
PP1V8_AON = 1.2-1.8V (not stable)
PP3V8_AON = 3.8V (stable)
Edit3: After measuring at PPBUS_5VS2_VIN the voltage on the usb-c meter jumped up to 20V / 0.07 - 0.40A (CPU getting warm)
PPBUS_AON = 11.96V (stable)
PP1V8_AON = 1.8V (stable)
P5VS2_EN and P5VS2_PWR_EN = 1V (stable) / 0.642
PPBUS_5VS2_VIN = 11.96V (stable)
P5VS2_PGOOD = 0.6V / 0.510
PP5V_S2 = Short
PP3V3_S2 = 3.3V (stable)
PP1V8_S2 = 1.8V (stable)
PP1V25_S2 = 1.25V (stable)
Detected via DFU mode - unable to restore. (due the missing PP5V_S2 rail)
Note: No image but I think that's due to the missing PP5V_S2 rail, right?
Edit4: Found the issue .... UC300 was shorted, I will order a new one. (P5VS2_SW was short to ground)
"Faulty UC300?"
You already said is shorted.
Replace it and check all adjacent components and traces.
Each one has series resistors on its output; RR7x2/3, 0 ohm, 0603 in size.
Remove the pair for each chip and check if problem persists.
BTW, write directly into bottom reply box, instead of clicking Reply button.
Issue fixed - RC853 was blown, haptic feedback is now working.
Note: PPBUS_AONSW_TPAD was missing.
Regarding the audio issue, I replaced all three amplifier chips - cracking sound is gone.
