KC Micro Tronix
This is strange......
Machine will show 5v on the USBC meter and read 0.01A for a second and reset.
When I disconnect the BMS the unit powers up and works! ( J6951 )
With the battery BMS connected it just bounces and resets. ( I have changed the battery using a tester and get the same result! )
I diode checked SMBUS_SMC_5_G3H_SDL / SCA and both are normal
I checked SYS_DETECT_L it also appeared normal
History on this system.
It was serviced by another technician for screen replacement. They changed the screen and this was the result. The original screen is back on and does function with the same defect it had before ( lines across the bottom of the screen ) and works normally if the BMS is disconnected.
SMC? What the heck?
SMC? What the heck?
