820-2327 No Hardware Installed
90% of the time it is either a fucked up cable or connector. Inspect closer and try a known good assembly. 13 and 15 are both compatible for testing the airport connector.
larossmann 0.2v in MINI_RESET_CONN and L3404 (PP5_WLAN) is burned. I just replaced, but still don't work.
That burns when someone plugs the connector on the card inside the LCD the wrong way around. Did L3405 fry again?
I told you why L3405 burned. So now this issue is probably a dead cable/connector or airport card. Start testing with a know good LCD and check if L3405 was not fried again by the old LCD.
