820-2327 quick ask
totosql
Hi guys can I use a 30k res in 22k res MCP_VID<0> out to GND this line come from MCP 39 or U1400 I fix this from water damage some res and cap lost I m put back but I dont have 22k just 30k but a no sure if i can use in this case... thank you
larossmann
I have no idea, one way to find out. This looks like a basic termination resistor to keep reflections out of the signal, on something that regulates mcp vcore... yeah i wouldn't fuck with that. just find 22k.
totosql
I got the res everything look good and boo white screen no chime no shit and think no the fuck res do some damage or something I take off from mb same, damm but a this mb work before install any cap o res so instinct i was cover two cap whit green shit because they little lose and i star from there c2531 c2535 i clean up around try boom the shit work wow but is kida rare i put some overcoat pen in little spot try it if i pick up some ohms nothing i m no sure w happen but it work now.
totosql
After I check everything run ok I found My usb front port fuck has power no broken line no aparente damage J4600 I follow the lines to u4650 this look like briged to smc debug mode i test the line pin 9 pp3v42_g3h pin 10 USB_DEBUGPRT_EN_L as power, that mean SEL=1 Choose USB s be work fine but no, any suggest ( other test j4600 pin1 5v pin2 3.33v pin3 3.32 v p4 gnd test p2,p3 = 0v look like they get some V front other place I did test the Other port was diferent p1 5v p2 0v p3 0v p4 gnd) any help is welcome thank's
Diode mode measurement on both data pins of USB connector?
You could remove U4650 and short R4651/52 to eliminate issue with debug MUX.
totosql
j4610 (good one) Diode mode measurement on both data pins of USB connector? = .931 j4600 (bad one) 1.630
totosql
totosql
I changed the d4600 test same problem so I follow u step eliminate u4650 two little bridge and done work nice thank you for help duke
