820-2494 Only first LED
No-Clean
Clean board just died suddenly.
First LED comes on with 12V are injected to PP12V_S5
When power button is shorted nothing happens and SMC_ONOFF_L stays at 3.3V
No shorts found.
PP1V1_S5_REG - 1.1V
PP3V3_S5_REG - 3.3V
PP5V_S5_LDO - 5V
PP12V_S5 - 12.05V
Missing 5VREG_EN and PM_SLP_S4_L
Im not very good with this old iMacs, any guidance will be greatly appreciated.
Use S5010 pads for test, instead of power button.
If starts, then bad power button, connector, or cable.
Be sure R5010 is good.
No-Clean
R5010 is good 1k
Diode mode on S5010:1/2 is same as J5010:1 so the connection is good
I am not using power button for testing, I am shorting J5010:1 to ground
No-Clean
Ok now it does, sorry for the hold up, it does drop to 0.300V when I short J5010:1 to ground, but only fist LED remains lid.
Check for drop pulse at PM_PWRBTN_L at same time.
If present, check for pulse at Pin 1 of U7300; this chip fails a lot.
Do you get correct voltage at L7920?
No-Clean
L7920 1.1V both ends
When I short J5010:1 to ground I get 3.3V on U7300:1 but U7300:12 still 0V even thou this chip was making that voltage on the donor board.
No-Clean
I put the chip back on the donor board and now it is dead, looks like the temperature when removing it is killing it or then I install it on the other board that board is killing it, Im a little confused here...
