820-2523 boots but no image
Board spins fans at max when power connected. And draws about 35w from wall. CPU VCORE is about 1v and PP3V3_S0GPU is 3.5V. No display, USB ports have power but no usb activity. I believe this might be a VGA coil short because I read that if L8920 has less than 4 ohms to ground it indicates a VGA coil short, and L8920 on my board measures 1.5 ohms to ground on both sides. Any advice appreciated.
will try reflowing both GPUs and update.
curious if there is a possible way to disable one NVIDIA gpu and not the other as this 2009 has two NVIDIA gpus.
reflowed both GPUs- Now the board runs fans at max for 3-5 seconds then turns off... any way to confirm what this could be?
also, if I wait a few minutes before booting, board stays on 10-20 seconds. If I boot immediately after it dies, it only lasts 3-5 seconds before dying again.
Edit: it actually was because I hadn't attached the heatsink, so board just runs fans full speed indefinitely. same as before.
Also tested SMC bypass mode and it doesn't boot at all in this mode.
MCP also fails after so many years.
Refllow is not a solution for these old boards.
You can probably find working one very cheap.
