820-2530 battery issues
R7040 is still there also
is a 6258AHRTZ
i assume the ISL rework and everything was working until a shitty charger did something to bring it to where it is now
could the ISL gotten fried and everything else be fine?
replaced the ISL and now it's running off of AC but still no battery, everything else looks fine any ideas?
maybe too much heat/time on ISL when I was putting it down? Do you think I should try another one?
pins 17/18 still giving 21.1k resistance
Dont need BGA machine, it is a small chip ..... Use your hot air station and preheater if you have, hot air station is enough if you don't have preheater, practice in donor boards first ....
