I don't have any history of the board i found a few of these a1278 model boards only and am trying to go through them and see if i can fix it(fan spin).
(I am trying to learn)
I have not tried the power button I did not know it was necessary to turn on thank you for that explanation.
L7770 gives me 1.06v on both sides
I do not know how to Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L. Does this mean press the power button then test?
I hope this "How to" collection will help our members. I will possibly modify this post in time, if updates available. Trigger SMC_ONOFF_L (PMU_ONOFF_L): It reffers to simulate power button function, when the keyboard is not connected. We need to do this when we work with the board...
The fan spin turns on when I press the wire to ground and goes above 1 amp for that moment. Is it normal for it to turn off after? Also I do not know how to check for drop pulse. The schematic shows the PM_PWRBTN_L is inside U1400 and U4900.
"Is it normal for it to turn off after?"
I hope you didn't maintain the short over R5015/16 pads.
Make just temporary contact, like pressing power button.
Yeah, PM_PWRBTN_L is not available on this platform; check reaction at PM_SLP_S4_L instead.
