820-2530, strange voltages on U7200
Mrit
I have a board with all of the G3H powerails present, but on of the S5 rails present.
I have the following measures from U7200:
Vin (pin 16) =12.61V;
Vref(pin 3)= 0V;
Vfb2(pin 5) = 285mV;
Vreg3 ( pin 8)= 260 mV;
Vreg5 (pin 17)= 17mV;
Veno(pin 13)= 14mV.
Is this indication of a bad U7200?
How do I go further testing and diagnosting?
Thank you for your time.
Mrit
Thank you for ypur reply.
Please find below the info requested.
V en0 (pin 13) is14mV;
In diode mode,
VReg3 = 0
VReg5 = 0
L7220 (pin 1 and 2) = 0.60V.
What do you mean by L7220/60, exactly?
"VReg3 = 0
VReg5 = 0"
Do you really have both shorted to ground?
You may want to say OL, but I'm not sure.
However, in diode mode (red probe connected to ground), you cannot get 0 (zero) reading there, nor OL.
"L7220/60"
L7220 AND L7260...
Mrit
Yes, sorry, my bad.
I meant,
In diode mode,
VReg3 = 0L
VReg5 = 0L.
Also, in diode mode L7220 is 0.601 and L7260 is 0.449, both measured to ground.
Also, I have to mension that cap C7280 is missing, but the pads/ traces around it position look ok.
Should be good to replace C7280.
You must get some indication on VReg3/5, if you measure diode mode with red probe connected to ground.
So you have missing SMC_PM_G2_EN.
This could be SMC issue.
Do you get green light on magsafe?
Be sure to use 60/85W original charger.
