820-2610-a board not turning on green light
turbo
820-2610-a 2009 macbook 17" 2009, no liquid damage, green light , not turning on , 8.41v=PPBUS_G3H, what to do what to do
it was turning on 2 days ago , any GPU issue ? or gpu caps ?
JohnB8812
I'm guessing 8.4 volts because that's what some of the older boards run on. If you're sure there's no liquid near the SMC or on the board, nothing to worry about then. I'd say see what voltage you get on C7771 when you short the power pads.
JohnB8812
My bad for that I just realized this is a pro forgive me my brain is scrambled. Let's start over, using known good Magsafe 1 85 watt? Voltage on pin 1 and two of the fuse?
