nate8organic
820-2610 boots apple logo crashes before it can finish loading. i had checked the c7777 prior to changing it and it was 1.17v, and i changed it out for a full size 330uf and its 1.17v still so i do not believe it has to do with the c7777. i double checked the osx and its good also. the only thing right now that i can not test to confirm is the lvds cable was a little chard but i cleaned it up and the screen turns on no trouble, i wish i had another duo screen to test this because i have seen a very slightly corroded lvds cable cause the same issue in the past.
Any ideas?
Any ideas?
