820-2641 with slowness when starting the machine.
iClub
This iMac, suffered contact with liquid in the region of the GPU connector and memories, where I cleaned and tinned some points. The machine takes a long time to raise the macOS.
iClub
I already noticed this test of the disconnected HD and go up through external macOS, I will clean the BIOS region ME ok?
iClub
I think I did some shit, after cleaning the ME region, the machine is not showing image, only giving 2 led. I think I inverted the HD cable in the SOURCE.
iClub
Friend, I turned the backup BIOS back to check if that was the problem, but it doesn't turn on and the cooller spins fast then spins slowly. I don't know what to do :(
Voltage: PP3V42_G3H 3.43V;
PP12V_G3H 12.06V.
