820-2850 fan spins for 10-15 seconds no cpu activity
Chuck60
Hi i have this board and I replaced a isl6259 which had a low PPBUS now I have 12.56v I found the I was missing PP1v05_S5 so I check u7600 area and all measurements where spot on I replaced u7600 and now the fan spins for 10-15 secs I went over the rails in diode mode and none are shorted :/ also no cpu activity with mouse And .859v at cpu. I removed heat sink think maybe no thermal paste but it was fine. All rails are fluctuating expect “PPBUS, PP5v_S5, PP3v3_S5” these 3 are stable. A tiny bit of water damage was on the isl6259 but that’s it. Here’s a video it’s weird because sometimes it’s spins longer than others.
Chuck60
Yes I checked them while fan was spinning all voltages and seem normal for the few seconds of fan spin but abruptly get cut of :/ I will check those pages 71/72 thanks for your help
Chuck60
Yes with memory modules removed same issue. it seems that even though I get ALLSYSPWRGD it powers back down it’s like I loose all my enable signals at once
Heat BGA chips with quality flux.
Maybe be a problem caused by accumulated crap.
If still the same, pass the board through ultrasonic bath too.
Chuck60
Yes I’ve done this it still does the same :/ with nothing connected just magesafe and also with just the battery.
