820-2877 Liquid Damage
Djsp
Hi i am practice on an old board a 820-2877-b, with damage from liquid, the board goes to S0, but no fan spin
PP5V_S0 = OK
PP3V3_S0 = OK
PP1V8_S0 = 0K
PP1V5_S0 = OK
CPUVCORE = 0
ONLY WITH RESET SMC STARTS
Do you really mean SMC reset, or just pressing power button?
Nvidia MCP platform boards don't start without pressing power button, as normal.
Post voltage for L7560, L7620 and L7710.
Djsp
you have to excuse me, I meant that if I do the reset procedure the smc starts with the fan at maximum.
L7560 = 0.022
L7620= 1.080
L7710= 0
"starts with the fan at maximum"
Do you mean SMC bypass maybe.
Board doesn't turn on in normal mode?
Post basic voltages for U7500; pins 14, 16, 22, 29.
Djsp
yes, in fact I said I am a beginner, then these are the measures of u 7500:
14 = 12.55
16 = 5.044
22 = 5.018
29 = 3.303
Djsp
Side A from the LVDS connector up to u7500 side B smc the circuit of the 3V42 etc. I removed it with some isopropyl alcohol, I rebuilt tracks on Q5315 and I also replaced it, and it works now I agree on U7500 I see if any capacitor pulls down, do you think I have to replace U7500?
Djsp
I replaced resistance and capacitor but nothing, I did a test with isopropyl alcohol on Q7560/65 and Q7565 heat evaporates fast I'm afraid it pulls down
Djsp
I removed the U7500 I realized that there is an interruption on pad 14 or the PPBUS_G3H pro pad to rebuild it and let's see what happens
But the question that arises is: did it stop by corrosion or why did the U 7500 go short?
Djsp
If I hadn't removed the U7500 I would never have noticed the interruption, I rebuilt the missing part now it works perfectly. It was very informative. Thank you!
