820-2879-B No wifi
VirtualLife
have runned ASD and there were no problems with that. Have tried other lcd and still no wifi. Installed new OS X and still nothing.
Tested the connector on the board....
Got 5V on L3404? Check continuity from pin 1,2,4,5,7,8,10,11,12 to the connector on the APX card.
Yes i got 5V on L3404.
Pin 1 0.378
Pin 2 0.377
Pin 4 0.455
Pin 5 0.455
Pin 7 0.105
Pin 8 0.105
Pin 10 0.000 Beeps all the time
Pin 11 0.491
Pin 12 0.475
larossmann
also tell me the tape is present over the pins. If the tape is not over the pins but that fluffy-thingie-that-sticks-to-the-cable-to-keep-interference-away is there it'll short the pins on the wifi connector.
I assume this was measured with the cable plugged in, else pin 1 and 2 would read nothing.
Don't you find it strange that pin 10 is shorted to GND???
Also if you want a reply to a post you should not "comment" on my post but "reply"
VirtualLife
Pin 10 is shorted to ground only when i connect the connector and i have tested a many lcds with good connector and still it says that is shorted. And yes i measured with cable plugged in and without cable.
Pin 10 to GND with connector inserted is correct. Please answer Louis's questions too.
Post measurements without cable inserted too.
Are C3430/31 L3401 looking ok?
Did you actually check if all pins have continuity to the connector on the airport card? 1 2 4 5 7 8 11 12 13? The common failure here is a fucked up connector on the board or a missing cap or coil.
