820-2879 kernel panic
Gmorb
board powers on and will only boot using a disc version of snow leopard and will then freeze on bootup after installing update. i also noticed some kernel panics is this issue solvable without doing any gpu replacements?
i saw a video louis made on how he fixed it but this was for the 15 inch. does the same issue apply to 13 inch models?
Must use PC8500 RAM. Other common one is the tape on the airport connector is missing and the conducive foam thing on the cable is shorting out the connector pins.
Gmorb
after installing 8500 ram it works no more freezing but now hard drive is not detected. will do further testing.
update:fl4501 was knocked off hdd being detected now
