820-2879 not turning on
Kyle93
Have a 820-2879 board that had mild water damage. After replacing u7000 and everything else that had corrosion I now get a green light and the board attempts to power on when pads are shorted but still no fan spin.
ALL_SYS_PWRGD is 0.871 V and cpu/gpu get warm without a heatsink.
Could this be a smc issue?
ALL_SYS_PWRGD is pulsing, or steady 0.97V?
CPU/MCP get hot even without trying to power on?
That's no good at all.
F7040 voltage?
Kyle93
ALL_SYS_PWRGD is 0V when system off. When turning on its a steady 0.871V
CPU/MCP only get hot when turning the board on by shorting pads
F7040 12.60V
Nothing on L7220???
"L7260 5v"
Means PM_SLP_S4_L comes high.
So other voltages should be present; the ones controlled by that signal.
As DDR voltage, for example...
Also check if PM_SLP_S3_L is high.
"PM_SLP_S3_L 3.332v"
Means board is now in S0 state...
Please post voltage on ALL coils of the board.
Kyle93
After closer inspection i didn't like the way u7500 looked so replaced it.
I have fan spin now but its not booting up fully. When I turn it on the sleep light blinks once and nothing else happens. What can cause this?
Kyle93
L7710 1.521v
L9701 0V
L6995 3.435v
L7620 1.073v
L7750 0.917v
L7560 0.956v
L7030 11.77V
L7330 1.520V
L7401 1.168V
L7400 1.168v
L7220 3.331V
L7260 5.07V
