820-2879 stuck on boot
ielectron
was slightly water damaged in the middle area on the board, not that bad, it was turning on when it arrived here
- than i put it in ultrasonic
-did not turn on
-after measuring around, seemed basically , so i reflowed the SMC, than it turn on again now,
-i can do SMC reset, nvram reset, there is chima, backlight picture
-i can always go in the boot menu
-it starts from usb stick, or internal hdd, but arund halway of booting just hangs in there and wont go further
ielectron
yes, i have a good test hdd, just used in another macbook, and i replaced the hdd cable
from usb it actually stuck halfway, on internal hdd it keeps restarting after about 1min of loading, and the line would reach abuot half way
JohnB8812
Ughhhh yeah this one will really really suck. If you're for sure, the cable and all the internals are good (battery etc), this could be anything. What is your resistance to ground on PP3v42 with no power applied/battery plugged in?
ielectron
it actually works with PC-8500S 2x2 gb, customer upgraded to 2x8gb 12800, the max amount of ram is i think 8gb anyway
this is an old core2duo laptop
