820-2914-b dim green light wont turn on
Gmorb
Board gets 16.5 volts and dim green light while using adaptor but i noticed certain points like pp3v42 and so on show 16.5 volts as if voltage is not being regulated. I connected the board using a benchtop power supply to force 18.5 volts and although i get the voltage set, amps are very low 0.0057 and still no voltage regulation. Ive replaced components which were not giving me a proper resistance or ohm readout on the 1 wire circuit but no luck.
Gurmon
if you got really 16.5v on PP3v42_G3H, This board is toast
Lets start with powerrails
PPBUS_G3H =
PP3v42 =
PP5v_S5 =
Then we can help you narrow the fault down.
So there is no 3V42.
Are you measuring resistance to GND on PPBUS with power applied? I hope not...
Resistance to GND on PP3V42?
Gmorb
Ok, resistance to ground on ppbus_g3h starts at 6.00 and keeps rising im assuming thats good.resistance to ground on pp3v42 is 33.0 and rises. I did further investigating and found that when i provided the board with 18.5 volts everything around the u6990 voltage regulator chip was shorting to ground. When i raise the voltage even further the chip would get extremely hot. Is it normal for everything to short around that chip? I went ahead and removed it and short dissapeared on all components around it. Bad chip?
What what? 6.00 Ohms, kOhms, mOhms? You are intentionally giving the board more than 18.5V? This is all a good way to kill a board.
I still need to know resistance to GND on PPBUS and PP3V42. A short on 3V42 will also cause U6990 to heat up.
