820-2915-a NO IMAGE OR BACKLIGHT
nate8organic
Hey, I just got in a 15" 820-2915 with no data or backlight. but has a good chime. i pulled the volts of all the probes to the lcd connector but am spending to much time trying to see what volts are wrong if any. any help in reading my results would be great! Thought it might have been the u8000 but im getting 3.4v at the lvds so i factored that out
Okay, I still have no image so perhaps its the lvds connector? i have tried it on 3 other screens with the same results. but from screen to screen i get dif results. some screens give me a few colored lines down it. but still no image or backlight. plugged into the external monitor i get an image. any thoughts here? I ran out of lvds connectors so until those come in i cant test that theory
Does it boot into OSX on an external screen?
Is SMC_LID high?
30V on backlight pins must mean there is backlight. Check BKL_EN and BKL_PWM.
It appears it does but i cannot get the main screen on the external and it seems pretty glitchy not sure if that is the hdmi port or the board.
SMC_LID is 3.1v open but is also 3.1v closed, if i understand correctly that should be dif when the lid is closed?
BLK_EN IS 3.1v AND BLK_PWM IS 2.92v
Also i noticed wile i was testing probes, (its possible that i touched 2 parts together with my probe) That the screen backlight had come on but quickly turned off. (also note all screens im using to test are confirmed working)
