820-2915-B Green Light, Fan Spin, No chime, No Video
Sr. Robot
Hello, hope you guys are all right.
So i have an 820-2915-B with charger light, fan spin, but no chime and no video (no mouse light). Theres no visible corrosion on the board. And i managed to turn it on once but no luck again.
PPVCORE_S0_CPU is 0.78v
U7400 shows no sign of damage at all, and CPUIMVP_VR_ON is 3.3v and PP5V_S0 lines are 5v.
What should i do next?. Could it be a bad CPU?
"PPVCORE_S0_CPU is 0.78v"
Looks like board is booting.
Did you check both USB ports for activity?
You can try disabling GPU in BIOS, to discard its failure.
Sr. Robot
Yes, i checked them both and no light on the mouse.
The GPU has failed long ago but it worked all right with software bypass. I cant disable it anymore because i cant even boot in safe mode. The LCD shows no image at all. Shouldnt a macbook 2011 still at least try to boot with a bad GPU?
Thank you.
Sr. Robot
I managed to turn it on, i noticed there was a corroded pin on the LCD connector, so i replaced it, and now it chimes and boots.
What i find weird is that there was no chime, no keyboard backlight etc, etc before the LCD connector replacement.
