Green light on charger, battery is present bot not charging. I'm very new to troubleshooting macbook boards and so far I've just been farting around probing voltages & getting nowhere in boardview. Any suggestions on where to start?
Remove the battery and start process repair.
Do not connect battery, until get correct PPBUS_G3H voltage.
Check diode mode to ground at L7030.
Post basic voltages for U7000; pins 1, 2, 3, 6, 9, 12, 13, 14, 15 17, 19, 20, 27.
Also check exact resistance between pins 17/18 and 27/28; measured on ohm scale, no power.
