820-2915-b
tipoti
hello,
The u7000 had exploded. I change it. The D6950 had exploded. I change it.
PP3V42_G3H : 1,7 -1.9 Volt no fixed
PP3V42_G3H :0.463 diode mode
U7100' 17/18 3.3 ohm 27/28: 21 ohm
pin 1: Voltaj yok
pin 2: 16.26 Volt
pin 3: 3.9 Volt
pin 9: 0,3 Volt
pin 12: 3,4 Volt
pin 13: 3,3 Volt
pin 14: 3,4 Volt
pin 15: 0,074 Volt
pin 17: 1,7 -1.9 Volt no fixed
pin 19: 5 Volt
pin 20: 5 Volt
pin 23: 1,7 -1.9 Volt no fixed
pin 26: 1,7 -1.9 Volt no fixed
pin 27: 1,7 -1.9 Volt no fixed
"pin 1: Voltaj yok"
Is the second time when I see this mention; I still don't understand what means.
Please, post useful information.
Q7080 may be bad, but need to know pin 1/U7000 voltage, to make an idea.
BTW, 3V42_G3H seems to be good.
"PP3V42_G3H : 1,7 -1.9 Volt no fixed
PP3V42_G3H :0.463 diode mode"
Do you mean PPBUS_G3H instead?
tipoti
I'm so confused, I'm in a hurry and I'm typing wrong. :)
Voltaj yok = No Voltage :)
maybe you can learn some Turkish :)
Pin1 : No Voltage
Do you mean PPBUS_G3H instead? Yes
PPBUS_G3H : 1,7 -1.9 Volt no fixed
PPBUS_G3H :0.463 diode mode
tipoti
Remove F7040/41 and check C7040 voltage.
c7040 : 1 Volt
i changed q7080
