820-2915 green light blink..PP3V42_G3H/PPBUS_G3H cycling.. F6905 diode mode 750
protocold
observation:
1) gmux jtag has flux and solder sign
2) L6995 come loose but solder is tight and continuity good
where should I start the witch hunt?
F6905 voltage fluctuates too?
If yes, try fake charger, or lab PSU.
You can have leakage on input stage; usually Q7080 issue.
protocold
yes voltage cycling at F6905.
Using a fake charger:
1) 16.46V at R7080 pin 1
2) 12.5v at F7040
3) PP3V42_G3H is 3.45v (measured at L6995)
no Fan spin.
protocold
you are right. Q7080 is bad, got it replaced, now green light stay, 12.5v at F7040.
But the fan now start and then stop. No ram.
PP5V_S5 5v
PP5V_S3 missing, diode mode 316
PP3V3_S4 3.3v
PP3V3_S5 3.3v
PP3V3_S3 missing, diode mode 254
protocold
sorry my bad... i think because i didnt put in the ram in there and so it shutdown?
Not sure what but the board seems to be ok now.
protocold
can you educate me what had happend?
1) why a bad Q7080 would cause a green light blink?
2) why using a fake charger would help identify the issue?
Original Apple charger is smart enough to detect leakage on the board.
In fact it has an embedded processor to control output voltage; only delivers 6V in the first 2s.
Do not imagine that chinese will place such a processor in their f***g chargers.
