820-2915 no WiFi
Chuck60
Hi I did some repairs on this board and I have it running but the WiFi is not working apparently it had a issue with WiFi before it totally died. The connector looks like it was scrapped maybe burned before and I did continuity on connector all pins. All have continuity to there external pins. I also checked continuity from
L3404 pin 1 to j3404 pins 22,24,26,28,30,29 all have continuity.
L3404 has 3.3 on both pins 1 and 2
3.3v is getting to pin 22,24,26,28,30,29
so even though the connector doesn?t look great it still is conducting. I?ve change both WiFi airport and cable of known working units.
Check L3401/73/74 and their continuity with J3401.
Also compare diode mode to ground with similar board.
No hardware detected on System Report?
Chuck60
Ok thank you L3401 must have gotten knocked of when I was working on it :/ maybe I jus thought it was a prior issue
thanks again
