820-2936 3 beep
MegaObi
ok i slapped it in... pressed button.
how does this even work?
must i power the board?
Do NOT power up the board.
All LEDs must lit.
Some of them (8 I suppose) will be at max.
If one LED stays off, corresponding line is broken (to CPU); or bad contact on the socket.
MegaObi
nvm. issue gone. ultrasonic the machine its all good. touched up first line of balls. i only seen the first couple go bad... not sure what else also someone tightened the screws real hard loosened them a bit.
