820-2936-b not power
tipoti
hi,
I saw that the PP3V42_G3H line was short circuited. U7000 was short I changed it. There is now a green light but it does not turn orange and the battery is not charging. Device does not turn on
PP3V42_G3H :3.4 v
PPVRTC_G3H : 3.3 v
PP5V_S5 : 5v
PP5V_SUS : 5v
"only wity battery"
I didn't asked that.
I expected the second reading with battery AND charger connected (as above mentioned).
Looks like no good communication through battery bus.
Check voltage and diode mode to ground on its SCL/SDA lines.
tipoti
I cleared the u2800 zone and the device turned on. But it doesn't turn orange. The best known battery. the device continues to work after unplugging the charger
Battery percentage is showed correctly?
To charge the battery, you must get correct PPBUS_G3H first; 12.6V without battery.
Check R7000 first.
SCL/SDA difference in diode mode looks bad; should be less than 1% normally.
Remove D6950 and test again.
