820-2936-b
Anterweb
I'm presuming this is something daft before I start stripping the board out but haven't seen it before,
Green light on charger, (no orange light) boots and runs fine! Just won't charge
Tried 3 known good batteries. But the odd thing is with the battery disconnected I get No green light and it won't turn on not even in smc bypass.?
What voltages did you measure on the board with charger alone (no battery)?
Did you disconnet the BIL?
Test the board alone on the desk.
Anterweb
Now have just the board on the bench, Nothing at all connected.
Just spent some time checking all voltages caps and resistors on page 64 of schematic. I cant seem to see anything wrong. all caps and resistors measure good,.
But i'm only get around 1.2v and slowley drops on f7040 measuring g3H.
Even when on the bench, I connect the battery and g3hot is fine again and i get a green light and fan spin again! but if I remove the battery f7040 g3h measures 1.2v and slowly drops until magsafe light goes dim green.
If i reconnect the battery all is fine but it wont recognize the battery or charge then if I remove the battery same effect voltage on g3h slowley drops until magsafe goes dim green
Any help much appreciated,
Anterweb
I convinced myself it was u7000 causing the issue and as I have a bunch of them I poped a new one on today, this has solved the problem with g3h dropping its now a solid 12.22v without battery connected starts fan spin, but fan runs fast!
Still no orange light on charger though. I'll try later to put it back together and see if the system can see the battery..
But looks like I have still got a not charging issue?
Anterweb
OK, I got it all back together in the case with everything connected. it now boots and runs fine off both mains and battery and with battery connected or not connected, but the system doesn't show a year on about this mac and it doesn't recognise any battery, I've tried 4 known good ones.
This has me stumped!
Anterweb
Just tried a known good bios with clean me I grabbed of this forum,, same result
It seems seems to now run and perform perfectly, from mains, battery or both connected, just no orange light no battery recognised
Did you try known good DCIN board?
Also test disconnecting BIL.
If stiil the same, post U6900/1 voltages.
Anterweb
Did you try known good DCIN board? - Yes tried 3 known good ones to be safe,
BIL I noticed on first removing the board that the BIL cable was ripped in two! ( Could this have caused the problem? must have been done when customer fitted a new battery ) so that has been disconnected for all testing mentioned.
U6900
SMC_BC_ACOK_VCC = 3.47v
gnd = 0
unconnected = 0
SYS-Onewire = 3.47v
Adapter_sense = 3.47v
U6901
1) SMC_BC_ACOK = 2.7v
2)SMC_BC_ACOK = 2.7v
gnd = 0
SMC_BC_SCOK_VCC= 3.47v
pp3v42_g3h = 3.47v
Anterweb
I presume you mean take the measurements here?
Only continuity from the center pin to pin 2 GND on U6900 all traces look good
Anterweb
ahh gotcha
ADAPTER_SENSE central pin of Magsafe connector to pin 5 U6900 tests fine for continuity, no problem there at all.
Without BIL connected, battery still not recognised?
Post diode mode to ground and voltage, on its SCL/SDA lines.
Tried known good battery for sure (not chinese new)?
Anterweb
batts.jpg I have a pile of these all genuine Apple and all in a good working condition, all same result,
BIL is removed from start of troubleshooting
Measuring SCL/SDA lines on J6950 i get
SDA = 3.46 v
SCL = 3.46 v
Diode mode to ground
SDA = 51.0K and slowley rising
SCL = 51.0K and slowley rising
K in diode mode, I don't think.
However should be good, as you got identical ohm values.
Remove SMC and check continuity for its traces to battery and U6900; then replace SMC.
