(820-2936) Battery not charging
phantom
Tried 2 differents battery, and 2 different power supply.
Tried reset smc
No luck
Always green light
Bolt symbol
But system says not charging
Any help? Thansk
What is exact PPBUS_G3H voltage, w/ and w/o battery connected?
Any history available?
Check diode mode to ground at SCL/SDA lines of battery bus.
phantom
11,54v with battery 12,57/8,3 in loop with power supply only, 12,57 stable with battery and power supply
i've discovered that i have orange light if i connect the machine and power off it
scl/sda 0,500
phantom
found the problem: r7052 were 18 ohm and not 0.
made a jumper and now orange light....and (i think) charging: it says "calculating charging time)
