820-2936 Charging Issues
tlough75
So tonight I have an 820-2936 on the bench from a customer who states they are having charging issues. They claim sometimes the battery will charge and sometimes it will not. So I took off the bottom and check the current sense resistors and they measure the correct values vs the schematic. I did take note that is it a knock off battery (Ansanour). Funny thing happens, when I try to turn the power off without an Apple OG Magsafe the computer will not turn on. When I plug Magsafe in it boots up. The battery indicator is saying 100% but as soon as I unplug the MS the computer shuts off. I put an older original Apple battery in and the computer will start on battery and MS. If I unplug the MS the computer stays running. The current battery level is steadily going down from 97% to 92%. My question is, is this simply a case of a bad battery? they said they have replaced it a couple times.
Board looks super clean also.
tlough75
No change after unplugging BIL. Knock off battery has 44 Charge cycles and has the "Replace Now" battery status. Max Capacity is 5288mAh.
