820-2936 - Ethernet never gets link.
gcain
Customer is a field technician, so no getting around not having Ethernet. /groan
The network card is detected and can be seen everywhere you would expect but it never seems to sense when a cable is plugged in.
I checked for continuity between 1,2; 3,6; 4,5. No pins are shorted to ground.
Any suggestions?
Bad connector? Plug in cable and check the pins on the other side like you did at the connector. 1-2, 3-6, 4-5, 7-8.
gcain
I did check 7&8, just forgot to type them.
LAN Chip being U3900?
He is a field tech, always plugging his lan into various devices; maybe D4000/1 (ESD protection) are faulty. This is similar to what I find on USB in fact.
I'll measure / swap them quick and report back.
gcain
So D4000/1 is NOSTUFF.
Turns out R4000 was burnt out. I swapped it but still getting no link.
