820-2936 Fan turn on and off cycle.
Dewanbd
This unit shows green light , fan spinning and off , cycle. Looks like no liquid damage.
Green Light - OK
PPBUS_G3H - 12.58v
PP3V42_G3H - OK
PP5V_S5 - 5v ok
PP5V_S0 - 5v and drop for 0v (turn on and off fan)
Y2805=1v
Removing memory turn on fan continue running and no memory beeps sound.
When machine boots, VCORE should drop to 0.8V aprox.
Seems like something goes wrong when CPU starts to work.
Doesn't spin the fan in SMC bypass at least?
Dewanbd
When machine boots, VCORE drop to 1 V and machine fan stop it drop 0V.
Doesn't spin the fan in SMC bypass, at all.
"boots" I mean machine working.
You reffer to turning on, which is not the same.
If VCORE steady 1-1.15V, no good; you must note a small drop, until aprox 0.75-0.85V
If board turns off with RAM and stay on without RAM, should be some issue with CPU, or PCH.
Bad communication with RAM is still possible.
Dewanbd
After 3 days there is no display, turn on,hear chime sound , see the screen light on but no display. Any help please?
JohnB8812
Rehot CPU is not a solution lol likely just heated dead chips and they worked for a few days. This board is junk
