820-2936 heating, "coreduetd" process using 100% process
VinceLx
Hello,
This machine had a dead keyboard, dead battery, but the board seems ok.
Test ASD144 is ok, but sometimes CPU temperatures are above 80º due to a "coreduetd" process using all the CPU time.
I found a solution on the net, namely:
  1. In the Finder menu choose Go -> Go to Folder…
  2. Type: “/var/db/coreduet”
  3. Delete everything in that folder
  4. Restart
Nevertheless no explanation on the origin of this, and if it can appear again.
So I wonder if this is not hardware related? How can I trust the board if issues like this can happen at any moment?
Software problems must be discarded with new installation.
Sometimes need to test with other disk also.
You should have USB preinstalled macOS for test in service...
