820-2936 No Hard Drive
Puevig reven
I have a 820-2936 that does not recognize the hard drive. The drive has power but I still get flashing folder. Tried new cable, etc. Everything seems to measure correctly. Any ideas?
Had the same issue a couple of days ago, tried a new cable still nothing. What finally woke the drive "recognition" was SMC reset.
Just to rule out the basics, I'm assuming you've tried another hard drive, or made sure that one isn't dead. Try an SMC reset like suggested above, if that doesn't work, Check U4510 to see if it's getting voltage and SATARDRVR_EN
btw, when I say check, I mean replace... how a capacitor passes the stupid signal your multimeter puts out is different from how it will pass a high speed data line signal.
Copper trace in the bends break. Traces are stretched when they bend the cable. Not 100% sure about the cause but I would say stress corrosion cracking is happening. Very common on copper/bronze that is cold deformed.
Why are they not breaking in the 15 inch models? Here they are also bended but I don't remember changing one. In 13 inch I change them every day.
