820-2936 re boots on battery
Bouba148
Brown Liquid damage like coffee or Coca
Green Light OK
BIL Light OK
No picture
No chime
Fan spins OK but spins to the Max speed
No CD drive Noise
Passed it in the UC: OK
Reinstalled in the chassis with the screen: OK Boots and works fine without battery
When replugging the battery it turns off and reboots during the loading bar around 75% and this with and without the charger plugged
I've let the battery fully charge over the night and tried : NOK
Tried with a battery completely empty: OK
After charging it few minutes, the same issue: NOK
Removed the battery again: OK
Where was the liquid spill?
Post voltage for pins 9 & 15 of U7000.
Does it enter to OSX with charger + battery, starting in SMC bypass mode?
Bouba148
@U7000
without battery:
9: CHGR_AMON : 0.300V
15: CHGR_BMON: 0.049V
With Battery:
9: CHGR_AMON : slowly rising to 1.13V
15: CHGR_BMON: 0.050V
The board is pulling 2.8A
After removing the charger the board stays ON.......Hummmm...........Fixed?
Fan runs a full speed
Bouba148
I think you can close this topic.
After re assembly everything together, The mbp is turning ON and stays ON with the battery, tested from 28% to 25% during around 10 minutes.
Strange because, the board was just resting during 2 months........sometimes Do NOT Rush.
Thanks
