820-2936 short fan spin on charger only, runs on battery
grmacs
This board ran on battery but had no green light. Found corrosion around Q5310 and that edge of the board and had .7V at SMC BC ACOK. Replaced Q5310 and got green light and PPBUS G3H and short fan spin but stops... PPBUS G3H stays steady at 12.62V once connected to power and after fan starts and stops.
grmacs
It DOES. Never used that to test before... what does that imply? AFter poking around the posts a bit... being it runs ok on battery does this mean then that SMC current sensing related to the charging circuit is awry?
grmacs
85w Charger only connected:
17/18 resistance 3.0 ohms
27/28 20.9 ohms
dCIN VSENSE 2.8V
PBUS VSENSE 2.1V
DCIN ISENSE 0V
BMON ISENSE 3.4V
grmacs
lost a pad on the smc trying to reball it. DOn't have another 2936 board! I'll have to put this one on the shelf until I get a SMC for it. I was thinking it had to be SMC related being the battery op runs fine and charger sensors seem to be reading correctly? Idk. I couldn't identify any sensor issues related to the pages you referenced but I'll try again once I get SMC back on it.
