820-2936 water damaged, battery not detected
Dewanbd
It was water damaged. closed to ISL, changed it and worked fine except battery not detected. Found
R5280=3.4V both side, R5281=3.4v both side. Checked BIL looks good. Any help please.
Check traces and solders for pins 10/11 of ISL6259.
Post resistance to ground at SCL/SDA lines of battery bus.
Also post exact voltage for PPBUS_G3H.
Dewanbd
traces and solders for pins 10/11 of ISL6259. looks good.
resistance to ground at SCL=.455 and sdl=.456
exact voltage for PPBUS_G3H=12.4 v .Thanks.
Bad SMC, or battery in this case.
I would test a known good battery first.
Also recommend you try another ISL6259.
Last solution, change the SMC...
Dewanbd
Volteges for U6990:
PIN9 P3V42G3H=1.1V
PIN8 P3V42G3H_FB= 4.9V
PIN7 PPVIN_G3H_P3V42G3H=16.6V
PIN6 P3V42G3H_SW=1.1V
PIN4 PPVIN_G3H_P3V42G3H=16.6V
PIN3 P3V42G3H_TON=11/12 NOT STABLE
PIN2 P3V42G3H_FB=4.9V
Check resistance to ground (diode mode) at L6995.
If good, check C6991/96 and R6995.
If all good, change U6990.
Be sure all traces and solders are OK.
