820-2936b It's not charging
tipoti
before me the u7000 was modified. I changed it to be sure. I tried with 3 different batteries. The green light does not turn orange. The device turns on but does not charge. where should i start
tipoti
PPVBAT_G3H_CHGR_R & PPVBAT_G3H_CONN : 10.54 voltage
CHGR_LGATE :. No voltage is this normal ?
So the machine doesn't work without battery?
Remove the battery and fix PPB_G3H problem first.
Check resistance between pins 17/18 and 27/28 of U7000.
