820-3023-A no boot
Sr. Robot
Hi, got an 820-3023-A that was running slow when the battery was connected.
It had some previous issues that were fixed:
1. 3 beeps no boot: RAM reball solved it
2. Corossion on LCD connector and U9310: both cleaned and replaced.
Then it ran slow when the battery was connected (w or w/0 charger). Tried different batteries same thing. Without battery it ran fine.
Then suddenly Q7260 exploded. I replaced it but now its not booting (i have green light but no fan spin).
PPBUS_G3H:8.4v
PP3V42_G3H: 3.3v
PPDCIN_G3H: 17v
PP5V_S5: 5.0v
PP5V_SUS: 0v
PP3V3_S3: 0v
Check all components related with L/Q7260 and corresponding side of U7201.
Post U7201 voltages; pins 23, 22, 12, 13, 29, 21.
Wasting two days to get a reply.
I wouldn't ask you for last checkings if you reply in time...
Do you get 3V3_SUS?
No short there, missing PM_SLP_SUS_L too?
Check PM_BATLOW_L, SMC_ADAPTER_EN, PM_DSW_PWRGD, PCH_DSWVRMEN, PM_RSMRST_L, PM_PWRBTN_L and the 4 PCH's RTC signals.
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
Sr. Robot
PM_SLP_SUS_L = 3.0v
PM_BATLOW_L= 0v
PM_DSW_PWRGD = 3.4v
PCH_DSWVRMEN = 3.1v
PM_RSMRST_L = 0v
PM_PWRBTN_L = 3.4v
RTC_RESET_L = 3.3v
PPVRTC_G3H = 3.3v
PCH_SRTCRST_L = 3.3v
SYSCLK_CLK32K_RTC = 0.4v
PM_PWRBTN_L pulses
I can't understand how peoples can still forget 2 of PCH's RTC signals; thousand times mentioned on the forum.
However, in this case seems to have a problem with Q7820/22.
Sr. Robot
I replaced Q7820, Q7822 and Q7840, D2400 just in case, but no change.
P3V3SUS_SS = 3.2v
P3V3SUS_EN_L = 3.3v
P5VSUS_EN_L = 4.8v
PCH_INTRUDER_L = 2.98 v
PCH_INTVRMEN = 3.2v
So missing SMC_BATLOW_L and PM_BATLOW_L.
PCH will not start power on sequence in this case.
Are you sure PM_SLP_SUS_L is high?
Try known good original Magsafe charger.
If still same, change SMC.
