Clean machine, no signs of liquid, boots up does not feel "jerky" when booting
From the moment the power button is pressed the fan runs 100%.
Tried Known good Battery, SSD, DC in, Dc in flex, Track pad, track pad flex and two different fans.
EFI Asd tells me : "Motor is running slower than it should" passes all other test. Can't get the OS ASD to load up.
Q5660
pin 1 3.3v
pin 2 3.3v
pin 3 4.58v
Replaced Q5660, R5665, R5660, R5661 no change. Tested continuity in all this area and seems fine.
Damaged trace to SMC ? Would be grateful of any hints!
Q5660
pin 1 3.3v
pin 2 3.3v
pin 3 4.58v
