820-3023 ppbus 8.40V is ok?
MDY
I have this board pretty clean. No liquid damage with ppbus 8.40. Not power. Customer says this air sometimes shutdown randomly and finnaly never power again.
MDY
Green light appear only with original 85W adapter. With no geunine no green light. Also with 85W adapter green light is faintly. I need dark room to see it. Same charger in macbook pro and all compatible green light is easy to see. That means something? Tomorrow will check S5 and battery too.
MDY
I have another working board with ram problem here and already interchanged IO boards and all the same.
Come on engage brains, green light issues have been discussed so many times. ACOK? SMC_RESET? Trackpad disconnected?
MDY
Only thing I found bad was CPUVCCIOS0_RTN from U7600 to the resistor. Before repaired this corroded trace I missed PPCPUVCCIO_S0_REG
After repair this trace I have PPCPUVCCIO_S0_REG stable at 1.05V
Only thing I miss now is CPU supplay and dont understand what more could be happend. No more corrosion found in the board.
