I'll try later new trackpad flex.
As for U5511:
pin 9 - 0.450
pin 10 - 0.469
R5260 measures 3.6kOhms on pins 2 (instead of 4.7kOhms). Taken off and it measures 4.7kOhms. Then I took U5511 off too, but same resistance.
I had somehow similar case with 820-2936 MLB.
Finally fixed it isolating PCH SMLink1 bus.
That was easy, removing two resistors (R5222/23).
Unfortunatelly no serie resistors present in your case.
You can try cuting off corresponding traces to PCH...
