820-3115 bad smc?
Kyle93
Have a 820-3115 that has no liquid damage, it supposedly just suddenly died. currently no green light. I have replaced isl u7000 since I was getting 18V on pin 2 but 0v from pin 14. Same results.
here are some voltages
PP3V42_G3H 3.42v
PPBUS_G3H 12.40v
SMC_RESET_L 3.42V
SMC_PM_G2_EN 0V
Is this bad smc?
Kyle93
Replaced SMC with a known good SMC but still same results. There was no crap under old SMC either
PM_CLK32K_SUSCLK_R is only 0.15V, could this mean bad PCH?
PCH requires 3V3SUS to send out PM_CLK32K_SUSCLK_R.
Post resistance to ground at SMC_PM_G2_EN (diode mode, red to ground).
Check voltages and signals for SMC (U4900 - 2 of 2) at page 45.
Kyle93
everything was working perfect including booting into OS but after going through the ultrasonic cleaner I have a dead board again.
ppbus_g3h only 0.690V
SMC_PM_G2_EN 0.434 resistance to ground
"after going through the ultrasonic cleaner I have a dead board again"
Do you have UC whitout sweep function, or don't use it?
Because I don't see other reason to damage the board...
Could be more dificil to fix the board now, than before.
Resistance to ground on PPBUS_G3H?
Post basic voltages for U7000.
Paul Daniels
Super Moderator
Sometimes also you might not have driven out all the liquid from under the chips like the CPU/PCH . Make sure you put it through the distilled water flush + alcohol + low bake + cool off; a couple of times I've had boards not start up after being in USC that ended up being because I was impatient and didn't give the board a chance to properly dry off.
Kyle93
Resistance to ground PP3V42 0.768
Not sure if my UC has sweeper or not, I use the crest P500H Louis recommended on the youtube channel years ago. He never mentioned about a sweeper function.
pin 2 17.80V
pin 12 3.42v
pin 14 0v
Have short to ground ON SMC_TCK Resistor R5080 came off along with corroded pad in UC. Have tried jumper wire but still no luck. Short is there even without R5080. Is this unrepairable now?
Kyle93
Paul Daniels didn't know and have never used a oven after a board has come out of UC. What kind of oven is recommended? Toaster oven?? How hot and how long should a board go in after alcohol bath?
"short to ground ON SMC_TCK"
A resistor can never generate a short; unless is not covered by corrosion.
In fact R5080 is the pull-up resistor, doesn't even go to ground.
Your problem is underneath SMC, or SMC itself shorted.
That means short inside board.
Follow the trace outside SMC and cut it off, trying to locate the part with short to ground.
Still possible to solve it, but not easy.
Very strange for a board without corrosion...
I think SMC requires high level on TCK line for normal operating.
The signal is not used, but its level can be critical...
