820-3115 - just turn on by pressing power
Palhano
Logic board with a lot of oxidation! No backlight on screen, fan turns and stops. If you press power for a few seconds, it turns on.
I changed components with oxidation, checked trails and reballing in the SMC. Checked the SPI resistors. The problem continues.
Palhano
hold about 5 seconds. If I just squeeze and release, the fan turns and stops, it doesn't turn on.
Fan normal speed is not fast.
I still think about SMC sensors issue.
Run corresponding EFI ASD test, or post a screenshot of HWMonitor.
Palhano
I was only able to run EFI after changing the BIOS chip.
has several sensor errors. =/
- Sensor - Current (1C0R) -- (PU High (Core/AXG/DDR3/I0/SA) (test 1)
- Sensor - Current (IDOR) -- DC In (test 1)
- Sensor - Current (IHDC) -- Hard Drive (test 1)
- Sensor - Current (IMOC) -- DDR3 (test 1)
- Sensor - Current (100R) -- Other <5V, 3.3V» (test 1)
- Sensor - Current (IPBR) -- Charger BMON (Prod) current (test 1)
- Sensor - Voltage (VCOC) -- (PUV Core (test 1)
- Sensor - Voltage (VNOC) -- AXG VCore (test 1)
- Sensor - Voltage (VPOR) -- PBus (test 1)
I changed the SMC, but it didn't change!
Palhano
discover a short in the AVREF_SMC line. Board working.
Backlight was a problem on the Q9706!
Now it's time to test everything! Thank you very much!
